Just lost some work again. Not a lot, but enough to matter, and it made me realize that out of my entire software stack, SketchUp is the only one where I regularly lose work. I turn autosave up to a fairly high interval because I find it disruptive, and it seems like the reliability of that autosave is sketchy at best. E.g if you open the file later, the autosave seems to get instantly scrapped, resulting in situations where you discover you lost work later and it’s too late to recover. It’s also very opaque where the autosave files even get written on disk. I’ve been using SketchUp for 24 years and I still have to Google it every time I need to go find it.
I understand that saving to Trimble Connect is frequently advised for a lot of reasons, with improved recovery/ state management being one of them, but Trimble Connect is a bad app. SketchUp is a good app, and should have a good, native, offline solution to this:
Write autosave files to a known directory that doesn’t require an IT degree to find.
Async write operation so that it doesn’t interrupt work when it happens, which would encourage people to use shorter intervals. Computers have been more than capable of doing 2 things at once for a few decades now.
Ambitiously, a mechanism that tries to take a file snapshot at crash. Bluebeam Revu does this incredibly well, and I almost never lose work there as a result, even though it actually has no autosave mechanism that I know of. It may not be a fair comparing a 3d modeling suite to a PDF editor, but it’s a very heavy app that handles very large files and performs complex markup operations on them. It would be extra valuable to have this feature in SketchUp just due to how frequent crashes are. Not necessarily 100% SketchUp team’s fault that this is the case, just a necessary evil of having a big extension ecosystem that many of us have become dependent on.
I respect your discipline but in my world, any manually triggered important action = a chance of a huge careless mistake inevitably happening. I’ve got keyboard shortcuts too but I’ve been in flow states where I worked 2 hours without remembering to save.
I’m surprised you’ve never had issues with it. I think I’m batting well under 500 for recovering substantial work after a bug splat.
I’m all for making autosaves more robust for those who seem to have frequent problem but that being said, like Paul I’ve never had a problem. Never in nearly 24 years have I lost any work in SketchUp nor have I ever had a corrupted SketchUp file.
I remember during CAD exams at school it was silent except for every couple minutes someone would call out “save” when they remembered to and everybody would hit save. I subconsciously save constantly now from that experience, I also version my files quite frequently so I can step backwards if needed. Would be nice to see an auto save feature that adds a version number.
so last week, in class, I showed that you can adjust the time, and I set it to 15 minutes saying that in average, I’d risk to loose 7,5min of work, blablahblah.
yesterday I got a powercut because of thunder. I checked, it was 14 min 40+ s after the last autosave.
needless to say, I’m back to 5min.
as of the corrupted files, same. but I’m most ly on mac, local save not usb stick, no onedrive stopping my saving process, no distant saving on a wonky connexion, it helps
back on topic,
yes, completely. twinmotion lets you pick a folder and a number of consecutive autosaves. really useful. sometimes, being able to go back a save or two and not just the last one can be useful.
well, if you have a good computer and if your file is slim and lean, it’s imperceptible. Off course, I train people whose computers are potatoes taped to a screen and who try to work on 500mb files, so off course it can’t smoothly save in the background. a 20M polygon file will cause a small stutter upon autosaving on an entry level computer. it’s either a sign you need to upgrade, or you need to delete the cute flower bouquet you placed in the entrance (that represents 19,5M polygons)
ideally, sure. not sure how feasible it is.
and since, unless I do something stupid a week prior and forget to cancel it, I’m usually on a 5 min interval, crashing and loosing 1-5 min of work is fine for me.
Actually scratch that, sometimes, due to plugins, I get the message saying that problems have been resolved (I turned it on by default). that usually tells me my file just got autosaved.
Imagine being a rock climber and ‘in flow state’ and forgetting to clip… part of flow is managing risk as well as just getting it done.
I would be all for having SKP natively produce incremental backups, and I too have a few times lost 10-15-45 minutes of work, but in general ‘save, save often, save as…’ has worked, with occasional need to make use of the autosave / backup file.
Don’t disagree but we’re talking about something (flow) that is in many ways outside of our control. Trying our best to save often is well and good but what naysayers in this thread are really saying is to encode “save often” as a habit. Automatic, not trying our best.
And anyway, the risk could be zero with a modern autosave mechanic.
With bluebeam I’m often working on 75MB pdf when the crash happens. I open the app again, it asks to recover, I click yes and it puts me at the exact change that I was doing that caused the crash. With about 99 percent reliability. It’s obviously storing the file state in working memory and dumping that state somewhere when it crashes.
There aren’t bugs and this isn’t a bug report thread. It could just be better implemented
The path where autosaves are written isn’t configurable. Other borderline irrelevant asset types are. This may be a windows quirk but, on my computer, they’re written to ~/AppData/Local/SketchUp/SketchUp 2026/SketchUp/working, a preposterous path. The solution is clear and probably requires between 5 and 20 total lines of code to implement:
My suggestion that the write be async was unfair because it looks like they have implemented that at some point. I didn’t notice because I’ve had my autosave interval at 30 minutes for years. I turned it down to 1 minute to do a test on a 25mb file and didn’t even notice the writes (there was no indication of them in the UI either). Good job SketchUp team.
The biggest flaw in my opinion, autosaves clobber themselves if you open the original file after a crash. It should time stamp the last clean autosave on any bug splat. I feel like sketchup maybe even used to do this for me so maybe it actually is a bug. The way mine seems to work is that it writes a file with the exact same name as my working file into that ~/AppData/etc/etc/etc/etc path, then overwrites the file over and over even after a new session. A naive user could have a crash and lose work, then open the file expecting a recovery wizard to popup up (as it does in practically every enterprise software written in the last 10 years) and by the time he figures out the situation, the autosave is overwritten with the old, unrecovered file.
Add a recovery wizard that pops up on startup after a crash and attempts to pull the most recent autosave - that would be a minimum viable feature. Bonus points if it can attempt to create a recovery file at the moment of crash. It has to know the state of the file in order to maintain the undo stack and I’m sure lots of other features.
I feel you might have a problem on your side, because what I understand of your description is already how I see it work on mine. idk if something is lost in translation or if the autosave isn’t working the right way on your machine ?
upon restart, sketchup will give a choice between the last save and the last autosave. only if you pick the last save will it discard the autosave. at least it (still) was for me last Thursday.
Unless you have a different definition of “recovery wizard”, but there is a clear red band marked “recovered” on the project that crashed or that you didn’t save, and clicking on them will give you a choice between the actual save if it still exists, and the auto save.
and if you don’t open sketchup, but directly double click on the file that crashed, you’ll get a pop up telling you a newer version exists and asking you if you want to open it instead.
off course, if the “naive user” chooses not to open the more recent autosave, it’ll be deleted because a new autosave cycle is starting. but they had the choice
No. I haven’t had those for years, if ever. And I’ve maintained an updated version of SketchUp Pro for all that time. I’d have noticed because I use a lot of plugins that don’t always play nice with one another and crashes are a fairly frequent thing. Probably at least one bug splat per week.
SketchUp is by far the clunkiest program I use daily, and I use a lot of applications in my daily work. I have no experience with any other 3D modeling software, so I don’t know if this is common. I do have a freelancer I work with who tells me Revit is as bad or worse. It’s hard to know what to think. He’s on Windoze, I’m on a Mac.
I have crashes or force quits every single day in SketchUp while I work. Sometimes I think I’m moving along too quickly for the program to keep up, but I have no way of knowing.
Of course, I use extensions, and everybody seems to think that it’s the user’s responsibility to figure out if the extensions work well together. Like we have the time for that.
It’s Trimble’s responsibility. They’re the ones who create the platform.
Take a look at Apple’s ecosystem: all their apps work together. They don’t crash just because you have two different apps downloaded from the App Store. Apple has control over the way apps are developed, and that’s how they keep problems from happening.
When you look at all of the different plugins available in the SketchUp ecosphere, every single one of them has a different interface, some better than others. A lot of them are very useful, but there do not seem to be any guidelines for controlling their development through independent developers.
Trimble, a global multi-billion-dollar construction services company, cannot be expected to test the permutations of the plugins and extensions that reside in the software they are responsible for developing.
But the end user, quite often just a single mom-and-pop operation with deadlines and commitments to meet, is expected to?
Really? How many permutations of the plugins have you tested? Do you have a list? I’d certainly like to see it because it would help me out. Apparently, you’ve got the time.
