I’m using a Mac and I’m trying to import a 2d image from warehouse into a floor plan. On my PC it works fine but on the Mac laptop the file is in the components window but I can’t drag it into the drawing. Any ideas on what I’m doing wrong?
You don’t suppose it could be that the toilet components, which are closer to human size are just too small to be seen in your nearly 10 kilometer wde floor plan could be responsible?
Well, to start, change the units for this model to millimeters in Window>Model Info>Units. Then use the Tape Measure tool to measure between the corners I show the dimensions connected to making sure you click at each one. type 9600mm and press Enter.
If your template is set to start you in meters, open a new file and change the units. Then save immediately as a template and make it your default.
