What is the best format to export my floor plan from CorelDraw to SketchUp?
I intended to to convert the 2D plan to 3D in SketchUp.
When I export it as PNG the image quality degrades so much in SketchUp … here is a screen shot:
However the exported PNG file is high quality as you can see it here:
Assuming you have SKP-Pro AND if your Corel is the Pro version; Export to DWG/DXF.
Otherwise, Export Corel to SVG, Open in InkScape (free) and Export to DXF. You still need SKP-Pro to import the AutoCad formats DXF/DWG.
Nino
Kenny
August 15, 2021, 2:18pm
4
As Nino mentioned DWG/DXF is best.
As a general point however, to display raster images such as PNG and JPEG legibly, ensure under ‘Preferences’- ‘Open GL’ you tick ‘Use maximum texture size’.
