stripping the layers for imports is not a good idea…
the geometry can be moved into groups, the group assigned to that layer and then have layer associations fixed…
LayerWatcher may also remove layers after imports [@TIG??] …
john
john
To remove all layers from selected geometry, or from geometry within selected ‘containers’ [component-instances and groups] - my LayerWatcher does have a context-menu tool ‘Selected-Geometry-To-Layer0’…
It also has several other useful layer-based tools too !
This snippet will gather ungrouped edges and faces by their assigned layer, create a group for each layer, transfer the entities to that group, and then reset them to use layer0 within the group. I wrote it to clean up models imported from CAD that use layers incorrectly for SketchUp. It preserves the structuring implied by the CAD layers but in a SketchUp-compatible way.
# gather up loose edges and faces
loose_faces = Sketchup.active_model.entities.grep(Sketchup::Face)
loose_edges = Sketchup.active_model.entities.grep(Sketchup::Edge)
# retain only edges not used by any face. Edges needed by a face
# will be handled along with the face.
loose_free_edges = loose_edges.delete_if {|edge| !edge.faces.empty?}
loose_geometry = loose_faces + loose_free_edges
# Hash with a key for each layer used by loose geometry and value
# an array of entities that use that layer. Default initializes a
# empty array so we can append items.
loose_by_layer = Hash.new {|h,k| h[k] = []}
loose_geometry.each {|entity| loose_by_layer[entity.layer] << entity}
# create a group for each used layer and put the associated geometry
# into it. Because a face must have all its edges in the same context,
# this will do two things: it will bring the bounding edges of the face
# into the group even if they weren't using this layer, and it will create
# a duplicate in the model if the edge is needed to bound a face still there.
# These new edges in model aren't in the list we built earlier but aren't needed
# because we captured only faces and free edges, not edges that bound faces.
Sketchup.active_model.start_operation("Group by layer", true)
loose_by_layer.keys.each do |layer|
begin
gp = Sketchup.active_model.entities.add_group(loose_by_layer[layer])
# use the layer from the original loose entities for the group
gp.layer = layer
# and fix the Layer0 association of the ones in the group
gp.definition.entities.each {|entity| entity.layer = nil}
rescue => e
# note: this reports the exception but lets the method
# continue to process the rest of the layers
UI.messagebox(e.message)
puts e.message
puts e.backtrace
end
end
Sketchup.active_model.commit_operation
nil
