When ever I click import, skechup just closes. No bug splat no nothing. Just straight up closes.
No matter what I do, when I hit file>import skechuop just dies.
What to do?
I did try to reinstall skechup, my computer is quite a powerhouse so that should not be the problem.
I remember the probem suddenley appered. I can drag and drop things
There is a problem I’m investigating, where the symptoms are on these lines. That is, file import leads to a crash, but drag and drop works.
Could you try a test where you drag and drop into the model, and if there is a dialog that lets you cancel, do cancel. Then try file import and see if it works.
Would it be possible to try the file you are importing?
I can drag and drop. That have worked forever, but I can’t file>import
You can see the file I’m trying to import. But it doesn’t matter. I’m not even at a point where I can click on a file. It’s not crashing due to clicking on a file. It’s crashing due to hitting import
