Is it possible to import an image then scale it to match the scale of an existing drawing?
I’m trying to model a large residential entrance doorway with sidelights. The image I’m trying to reproduce doesn’t have dimensions. Even if it did I suspect that the door would be the usual 3/0 x 6/8 and I want to size if for 3/6 x 7/0.
It seems that if I could import the picture and scale, my task would be far simpler.
Yes. After importing the image make a component of it. Open the component for editing and using the Tape Measure tool, measure between two point at a known distance and type the correct distance. Press Enter. I like to add crossing guides or an eedge to measure although that’s not a requirement.
I managed to copy the image, save it, then import it into SU Make; but I can’t seem to make it a component. Is that a limitation of my skills or of the Make version?
