Hi everyone,
I’m having trouble importing a .vrscene file of a floor plan exported from 3ds Max. When I import it into a blank SketchUp file, it works perfectly — the materials look fine. But when I try to transfer it from the blank file to the one I’m working on, the materials are either lost or don’t display correctly.
I’ve tried both copying the object and importing the .vrscene file directly into the working file, but nothing changes.
Does anyone know how to handle this issue?
Thanks a lot,
Best regards,
Guido
Ciao a tutti. Sto riscontrando problemi con l’importazione di un file di una pianta .vrscene esportato da 3d max. Quando lo importo in un file vuoto sketchup è perfetto, i materiali si vedono bene. quando provo a trasferirlo dal file vuoto al file a cui lavoro perde i materiali o si vedono male. Ho provato sia a copiare l’oggetto che ad importare il file .vrscene direttamente nel file a cui sto lavorando ma non cambia nulla.. qualcuno sa come gestire questo problema?
Grazie mille,
Hi, thanks for your reply.
I didn’t import a DWG file — I only have a .vrscene file which, when imported into an empty SketchUp file, displays perfectly.
But when I move it into the SketchUp file I’m working on, the materials don’t display correctly.
How can I transfer it so that the materials remain exactly the same?
Sorry, misspoke. Can I try your file after the .vrscene import, when it looks ok? I want to try copying that into another file to see if it still looks correct.
Thinking about it, I might need your working file as well, in case that has something strange about it.
Or, can I try the .vrscene file, and can you say how you import that into SketchUp?
