Imported STL file it is not a solid and cannot modify it here is file
You didn’t attach the file…
Likely if you set the import units to Meters you’ll find the object is solid. Sharing the .stl file so we can see what you are working with would help.
To @DaveR 's point, stl files, especially containing small objects, are notorious for being filled with tiny triangular “splinters” containing edges that are shorter than SketchUp’s minimum length tolerance. SketchUp merges their ends, and in doing so, loses the associated faces. Importing using meters will often overcome the problem (stl files contain just numbers, with no specified physical units).
