I am wanting to import a line drawing from corel draw 11 into su and struggling, i have tried PDF, DXF Bitmaps and tifs but with no avail! Can anyone offer a solution?
Regards
Stuart
You should be able to import DXF or DWG files without any problems, if they are exported in a version prior to 2020. You can also import BMP and TIFF files, but as Images.
The DWG format for AutoCad 2018, 2019, 2020 and 2021 is the same. Autodesk might introduce a new format next year.
When importing, check that the import unit is the same or possibly larger as used when exporting from CorelDraw.
Hi Mihai
Thanks for your help in this import problem, it worked in DWG on a older version thanks very much.
Stuart
This topic was automatically closed after 186 days. New replies are no longer allowed.
