Import error from dwg. file into SketchUp
I want to import .dwg file from AUTOCAD Plant 3D into SketchUp 2024 using import function, but it shows ‘import failed’.
K3_Plant_Layout.dwg (2.1 MB)
When you exported from AutoCAD Plant, did you set the export for DWG AutoCAD?
without proper exporting to dwg (probably)
skp
dwg
Hi, thank you sooo much! I tried for several hours and failed to import. Instead of import the original saved file, you need to export to a new dwg. file and it can be imported.
Thanks again!
image|690x388
