Hi, I am hoping to use custom attributes for components in Sketchup, and map these to IFC properties so that they can be exchanged/ exported. I have attempted to install IFC Manager, but it doesn’t appear to work as I envisaged, in that it doesn’t add property sets based on component class, nor does it enable me to map attributes to IFC properties, both of which I understood from searching online were possible. Can anyone suggest how I can do this? Thanks
I’m using Sketchup 2026 Pro for Desktoo
The Ifc manager adds the common property set of an entity type only (object needs to be a component.
Do you want to add additional pSets? Or use the one provided by ifc4/2x3?
Thanks for the response. For some reason IFC Manager doesn’t appear to be working for me, it’s not adding any properties to components I’ve classed as IFC entities. I would like to use IFC property sets where possible, but we certainly need additional properties too
You can try this SketchUp Plugins | PluginStore | SketchUcation
Here is a YouTube tutorial https://youtu.be/Lg9M2k6qXlQ?si=1uh_3v2igXH8Lu_P
You can choose English audio
Thanks, I’ll give that a try
And you may want to check out Jan’s other plugin, depending on exactly what you are looking to do:
