Hi there,
I had an issue with importing an .ifc -file. Unfortunately I couldn’t import the the ifc walls. Why is this?
I tried severel ifc-viewers and they all display the walls. It is a ifc 2x3 format
Perhaps someone can help me, or fix the problem
thanks
spb
The zipped file (inside Wiedl Dach-.ifc: Wiedl Dach-.zip (136.0 KB)
Hey djoseph, thank you for your response…,
the .ifc format is exported out of dietrichs software. Every ifc-viewer I tested was able to display the walls. I tested bim vision (bimvision.eu), solibri (www.solibri.com). All visible. Now I tested trimble connect and it was not able to display the walls too. I think its a sketchup / trimble thing…
Here is my skp file: Wiedl Dach-.skp (4.7 MB)
I wonder what BIMSight would show. It is Trimble’s free IFC viewer. We once had similar problems with it not showing something that was no problem for Solibri.
Hi!
Now I used the FZKViewer from the Karlsruhe Institute of Technology (https://www.iai.kit.edu/english/1302.php) and opened the file. The following Structure is shown while opening the file:
. All parts are shown. In ifcWallStandardCase there are 15 entries. And they are displayed too in this viewer.
The viewer has the possibility to export as .dxf. Now I opened the .dxf-file in SU and am going to the Outliner. Here are several ifcWallStandardCase Components visible. Even tags where made. What is not visible (in the .dxf Import) are the IfcBeam and IfcMember -components (but in the .ifc Import)
Huh… this is going to be complicated,
I solved the issue in my way, so I can work now, so I am just fine for now.
…hoping someone can at least improve this little import struggle
Thanks
I saw the import results in SU, the 15 IfcWallStandardCase-Walls are listed, but they are not showed in the outliner as they are when I import the .dxf twin (produced over FZkViewer)
I just had a look at the ifc-import thing at this forum, and found out that the problem with importing walls is existing quite a while…
…they say trimble is the one to put the finger on…-)
it would give me pleasure if there was the possiblity to strike in a new path towards solving, rather than persisting of this issue… sorry 4 my bad english
First one is: solibri
Second one is: ZFKViewer
Third one is: XBim Xplorer
4th one: is my beloved sketchup
picture one to 3 are showing walls, skechup sadly not.
…hang on trimble guys (if someone reads this) please provide wall import 4 sketchup
