Added a “Create Grid as Group” option and a “Delete Selected Faces” button.
Quick sketch to create contour lines.
Quickly get rid of faces to get ready for contour generation.
Trying to improve the UI. Changed to icons for buttons.
Grid Generator Settings now in drop down. Options for Imperial or Metric, create as group, with either guides, guide points or both.
Added a cursor icon and a highlighted active state for the Selection Tool button.
Added file selection and swap with icons.
New extension: MoveToPosition
Activate with toolbar button. Select position. Prompt displaying position. Then select component or group to be moved to the position.
Tried making view draw ‘targets’ to show the selected move-to position.
Tried alternative to MoveToPosition, CopyToPosition. One component or group is copied to each selected position.
PointToPoint toolbar button. Select group/component, then select a point to move it to.
A Gizmo for no reason… could not get it to work with onLButtonDown alone because of some funny business with the right mouse button. Thanks @dezmo for the getMenu example!
Added 3D Grid options:
Revamped the first extension I posted here: Make Group. Selected groups and components can be grouped and named with a prompt. Edges and faces are ignored. New icon isn’t heinous to look at! Added entry to the Tools menu so a shortcut can be created (I’m using ctrl + G).
Made a Make Group Html Dialog extension that mimics the look and feel of the SU Make Components function. You can name or misspell groups as you go!
Made a new little extension: SketchUp Notebook
Take note!
A few adjustments to the note taking extension. Save and load notebooks.
Extension doodling. What would be cooler: focus on a 2D drawing space or some new-fangled 3D thingamajigger? In either case, what?
An addition to the Outliner. What do you think, @RTCool ?
Good job!
That’s great! Did you do that at a plugin?
Thanks! Yes - it’s based on your example: Multiple tags on an entity, mid-2024 - #6 by RTCool
I’m going to try to add the visibility eye icons in a bit. Then try to get the styling squared away.
If you could use tags in this way, would the ‘ease of use’ make up for a lack of multiple tags? Or would you still prefer multiple tags? Also, do you like the idea of handling tags in the Outliner (or something like it) more than dealing with them in the Tags panel? Meaning you don’t want to create tags and folders but just want to handle tag assignment and visibility while navigating in the Outliner?
What other features do you think would be useful in the Outliner Options Panel (The OOPs controls ;^)? Renaming, Make Unique, etc.? Would you add attributes for other things?
Made a few changes to the Outliner Options, including adding Show/Hide visibility toggling and searching/filtering components and groups. Not sure how tags/folders and their visibility toggling fits… or if it should. As a ‘panel’ maybe.
