I try to open the project and the error message "failed to open document" always appears
I try to open the project and the error message “failed to open document” always appears, it was saved perfectly, I already tried opening the backups, there was no power outage when saving and I also didn’t save it in the cloud, I saved it directly on a hard drive, someone Can you help me recover this project? I’ve already tried opening it on other computers…
link to the files that are causing the problem:
Your 2.skp file had a problem which was easy to detect and easily repaired.
Here’s a link to the file
Thank you very much, what did you do?
The file 2.skp contains around 100,000 bytes of possibly random data (possibly from an earlier version of the same file) that were included when the file was saved. The errant bytes are at the end of the file after the valid data. What I did was, open the file in an (Hexadecimal) editor, and delete all of the extra bytes.
This problem isn’t common, nor is it unusual. I see this error in about one in fifty broken files that are posted on this forum, well, maybe fewer.
