here are some screenshots to show you the problem, you can see that there is a slight mismatch between the crate and the hatch, however Sketchup tells me that they are well aligned.
I tried to adjust it manually but nothing worked.
Do you have any tips and solutions for me?
Here is the 3D model: Caisse Panzer III B.F.skp (9.8 MB)
I use Sketchup Make 2017.
thank you for reading me, have a nice day.
Hi I took a look at your model. It’s really hard to know what part you’re talking about. The images aren’t clear.
But I took a look at the hinge part that’s attached to the tank and saw that the lines aren’t horizontal or vertical. I thought it was an easy fix but it’s not.
You will need to remodel that part completely with a style showing axes to ensure you’re keeping everything on track. Group the elements that you need to remodel and then use the [Hide rest of model] setting to isolate the geometry you’re working on. Colour by axis style setting.
