I don't know why I put the dimension that I want my square or rectangle it don't work can someone can help me please
it erase my dimension too I don’t know why it’s happening
Looks like you’re not entering the dimensions correctly. You need to type the two dimensions separate by a semi colon. Exact same format as the dimensions that are displayed in the Measurements window as you are dragging out the rectangle.
So I should write it like this ~5’ ; ~ 5’? Is there an another option that can let me write the measurements like this 5’,5’ or no
No. Don’t use the tildes. Enter the dimensions as 5’;5’. Use the same separator as shown.
You can set your computer’s localization to the US or another country that uses a period as the decimal separator and then you can use a comma between the dimensions.
The tilde only indicates that the dimension falls between the increment you have selected in Display Precision but you cannot enter a tilde as a dimension and shouldn’t even want to.
Okay men thank you very much now it works have a good night👍
