Newbie here, so I’m hoping this will be a simple issue for most of you…
I’m following a tutorial for modeling a simple table - a rectangle, 4 legs, 4 rails between the legs located flush with the top of the legs - this is important to note, and a top. after creating the top, when I try to push the top up to create a 1" thickness, Im left with 4 slots around the table exactly where the rails are; not the top surface of the legs, just the top surface of the rails. I’ve reviewed the tutorial several times and I can’t figure out what I’m missing.
Thanks in advance for your help.
Edit: I figured It would be something simple… I discovered that I didn’t convert the rails into components. That fixed the issue.
