Thanks Gully,
I just stumbled on to that. Now since I have made unique one of the shoes I should be able to raise the sole a half inch or so.
Thank you very much for your interest and your response.
Adam
Thanks Gully,
Adam
Uh, I think you have âflippingâ and mirroring with the Scale tool confused. I guess youâve been using scaling to -1, and, sure it matters which scaling handle you use.
But I was talking about the Flip command, which is located on the right-click context menu for applicable items. It goes, right-click > Flip along > Red Direction | Green Direction | Blue Direction.
You ought to give it a try.
-Gully
Thanks Gully. I found that if I get the right handle on the scale tool I get the desired result. I have been working with Mirror command since the early 90âs when I began to learn photoshop. This just did not do what I wanted it to until I saw the part âflip overâ accidentally so that it was essentially the same part as the first just upside down. I played for a moment then it inverted so that I had the correct configuration.
Now I fooling around with PCPTE filament and trying to get it to print.
Gratefully,
Adam
