HtmlDialog #write_image alternative
on a mac,
I can use a builtin system call to take a screenshot of my dlg using it’s position and size…
# screencapture -R top_left_x, top_left_y, width, height, image_path
%x[screencapture -R100,100,1024,1024 /tmp/outfile.jpg]
it seems on windows I could possibly use a gem to achieve the same…
require 'win32/screenshot'
# Take a screenshot of the window with the specified title, client area (e.g. without title bar)
Win32::Screenshot::Take.of(:window, title: 'my_dlg', context: :client)
.write("c:/tmp/outfile.jpg")
has anyone tried this gem in SU?
john
What is the use case for this? To my understanding WebDialog#write_image was a somewhat dirty hack to download map imagery for Geo Location.
I’ve got a couple of image editor extensions that used write_image…
a lot of things I switched to image_rep, but it gets very expensive when all you need is a thumbnail with some text…
I don’t see why you would think it was ever a hack…
john
I don’t see how it could not be a hack. It makes little sense in itself and must have been added for geo location, which actually relied on it. Rather than “properly” fetching images in the background from a server, it snapped a screenshot, which could include completely different content if you minimized SketchUp at the right (wrong?) time. Sure, it did the job, but it was not very sophisticated nor elegant. Classical hack.
Although it installs the gems okay via …
Gem::install "win32screenshot"
#=> [ #<Gem::Specification:0x100086c77a4 ffi-1.11.3-x64-mingw32>,
  #<Gem::Specification:0x10025b042dc mini_magick-4.10.1>,
  #<Gem::Specification:0x100088437a4 rautomation-1.0.0>,
  #<Gem::Specification:0x100088e5130 win32screenshot-3.0.0> ]
… it does not work “out of the box” …
… results in …
Error: #<TypeError: no implicit conversion of Sketchup::Console into String>
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/logger.rb:628:in `open'
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/logger.rb:628:in `open_logfile'
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/logger.rb:584:in `initialize'
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/logger.rb:318:in `new'
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/logger.rb:318:in `initialize'
C:/Users/Dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Gems64/gems/mini_magick-4.10.1/lib/mini_magick/configuration.rb:97:in `new'
C:/Users/Dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Gems64/gems/mini_magick-4.10.1/lib/mini_magick/configuration.rb:97:in `extended'
C:/Users/Dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Gems64/gems/mini_magick-4.10.1/lib/mini_magick.rb:6:in `extend'
C:/Users/Dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Gems64/gems/mini_magick-4.10.1/lib/mini_magick.rb:6:in `<module:MiniMagick>'
Since HtmlDialogs use somewhat “modern” web APIs, I could imagine one does not actually need a SketchUp method for doing this (and not even depend on a system utility hoping that it is available on that OS version and that it finds the right window).
It seems one has to make a “copy” the html of which you want an image in a canvas and then save it as pixel data or file. There certainly exists a library so you don’t have to implement it by hand.
Maybe html2canvas with fileSaver.js:
import html2canvas from "html2canvas";
import { saveAs } from "file-saver";
html2canvas(document.querySelector("body")).then(canvas => {
    canvas.toBlob(blob => saveAs(blob, "pretty image.png"))
I assume for geolocation they needed one complete image (not 20-50 tiles) and including the Google logo (separate html layer). If Google didn’t provide a JSON request API to generate such an image on their servers, then this was the best way to comply with the requirements. Still it’s questionable whether to make it a public Ruby API method if you don’t plan to maintain it forever.
I have some rgba images where converting the pixel data fails in canvas and in image_rep…
I don’t know what app originally created them but the have background gradient that is hidden with alpha set to 0…
heres one…
IceAlpha
imageMagic, imageRep, canvas will all return a coloured mask unless I do multi format step conversion…
using a screenshot I get this…
john
