Currently using sketchup make 2013 to import google image into plan view feet and inches template in order to lay out solar panels on roof surfaces of the image. In sketchup make 2014 the plan view feet and inches template isn’t listed. How do get to that template?
Hello Vince,
You can chance your template from the Preferences area. The CONSTRUCTION DOCUMENTATION is a template that uses Feet/In in plan view.
You can also create your own template by setting up a document the way you wish to start and then go to File>Save As Template
Cheers
CD
You’re a genius Chris - it works. Thanks!
Best Regards,
Vince Jakimzak
Solar Division Sales Manager
Jamar Power Systems
9830 Prospect Ave Ste D
Santee, CA 92071
Office: 619-448-7770
Mobile: 805-338-9962
vince@jamarpower.com
Regardless of template, you can change the units you use to model at any time from Window menu>Model Info>Units. Choosing a template doesn’t force you to keep using the default units saved in the template.
Anssi
Hi Vince
Save your settings as a Template.
Make that template the Default Template and SketchUp will remember all your settings.
See:
What are templates and how do I change the default template? — SketchUp Help
Creating a template — SketchUp Help
-Geo
