How to rotate a component around its center point in orthogonal axes
I loaded a kitchen sink into my model from the 3D warehouse. It’s 180º rotated from where it should be, so now I need to rotate it in place around a vertical axis through its center point in the two horizontal axes. Because it’s a complex component with all kinds of non-orthogonal surfaces, I can’t seem to find a place to select and then rotate it.
Any tips?
I’m guessing without looking at a skp, but it sounds best to use the move tool to rotate around the center of the sink.
Thanks - I found the solution. It’s been a while since I’ve done this a lot. I wasn’t even using the Rotate tool. I had grabbed the Offset tool.
Also possible by just rotating around an arbitrary point and moving it into place with the move tool after that. @Royce has the easiest way though…
Thanks - that’s what I ended up doing.
