Is there an extension or script that would allow me to replace (selected) guide points with components?
I have a site survey with guide points representing the the point cloud from which the terrain contours were generated. I would like to replace them all with a mark component so that I can add height data directly to the points.
I tried searching both forums but didn’t turn up any results, so I suspect there isn’t (yet) a plugin or script that does this. If anyone knows of one, or another way to accomplish this (other than manually) it would be a big help.
Thanks,
Doug
(I’m also posting this at the other forum, but I’ll check back on both for replies)
I know that approach would work, but Cotty ID’d the extension I was looking for… and I’ve already had it installed for years!
Problem is there a so many extensions with so many features and functions that it’s impossible to maintain that catalogue in your mind — especially for plugins you don’t use all the time…
Which makes me think that an index (database) of function by extension would be incredibly valuable: maybe the SU team could create it and populate the categories and most common functions, then have developers fill-in their entries when they upload/update their stuff of the EW.
I would also allow you to quickly ID overlapping functionality of installed plugins and do comparisons by function.
