How to remove a pre-loaded object
#1
Hello, I am fairly new to Sketchup and installed an extension “Cleanup3” by ThomThom. Now every time I open Sketchup it shows a model of Makerbot where “Chris” used to be. I uninstalled the extension, closed and re-opened Sketchup but this Makerbot image is still there…how do I remove it?
My main concern is that my Formlabs 1 printer software is now giving me size and support errors every time I bring files into it.
Thank you in advance for your help
#2
That sounds like you have set the 3D print template as your default. It contains a component for the printer volume. Most people find the volume to be unhelpful and unnecessary, so open a simple template instead.
#3
That was it! Must have done it around the same time as installing extensions. Thank you so much!
#4
Also note that like any other component, that “3D Printer” component remains in the In Model components collection even if you delete it from the model space. Go to Window>Model Info>Statistics and click on Purge Unused. The components and the materials they use will be purged from the file.
#5
Thank you for the info, I followed the steps and did as you suggested. It is greatly appreciated!
#6
