having trouble sending information to HP wide format printer. Can’t get to print actual size even though
the drawing size is within the paper size in the printer
Are you using LayOut?
What version of SketchUp? Please complete your profile.
if in layout do you have the default paper size set to the size paper you want to use?
Choose File>Document setup
In the popup menu: in “Paper” do you have the paper size set to the size paper you want to print to?
If not it will always assume that you are printing to the default paper size you have chosen regardless of the printer and will scale that to whatever scale you choose in the printer settings.
I had fun figuring this out when switching between printers.
