Hi screw3d
Thnak a lot for your reply.
Yes, an haet.set insert is a good idea as well. I already used it, but my idea was to go ahead as much as I can without insert.
However, for this need, I am nt sure if insert will help?
Under my box (in that picture, I turned the box in the oposite side), I need to fix the 4 “coupole” where a barometer will stand.
My idea is to insert a cylinder with thread to fix the coupoles to this “plate” (do not pay attention to the deept of the two other hole) as I demonstrate here without the coupole)
That the reason why, I need a “femal” and threaded cylinder.
Initialy, I used a metel threaded cylinder with heat-set inserts.
a couple of tips for M4 in a printed part, since a printed M4 thread (0.7 mm pitch) is right at the limit of what prints cleanly:
Yes, I am agree.
It’s absolutely not necessary to have M4. It can be M5 but not so much. (I do not have a tap).
Now, if the pitch is larger (or bigger), it’s fine, as long as the bolt (in the plate) and the thread cylinder fit.
The experience with the metal threaded cylinder, was not so good, and building a tread cylinder and a bolt is a nice challenge to maximalize the use of 3D printing.
As I am using the web version, I guess your plugin will not work but I appreciate your proposal (I quickly read the previous version of your post, this after noon)
may be would it have another way to fix the cylinder into the plate?
May be, I could use a no-threaded 3 cylinders (I do not know to explain it in english). After, I inserted it into the coupoles up to the plate, The 3 cylinders are inserted into the 3 holes, and then I turn the cylinders of 90° to fix it into the plate. But I am not sure it will be reliable,
