Right. I did not address this. Perhaps another boolean arg to decide whether to purge or not ?
Well with regard to selective erasing … perhaps change …
cdef.instances.to_a {|i| i.erase! }
… to …
owner = i.parent
next i.erase! if owner == i.model
next if owner.count_used_instances == 0
i.erase!
Note: This isn’t likely 100% foolproof either. There could be a situation where a definition has a mixture of used and unused instances.
next if ( groups ? !cdef.group? : cdef.group? )
… is a bit confusing. It can be rewritten as …
if groups
next unless cdef.group?
else # only component instances
next if cdef.group?
end
In terms of performance, avoid entity.erase!
inside a loop. Collect references to all entities in an array then use entities.erase_entities
to perform a bulk erase as that’s much faster.
Similar, avoid modifying the selection within an loop, updating the selection updates the UI which in turns slows things down. Collect references and add/remove to the selection in bulk.
Makes sense. Thank you
