Hi! I im modeling a parking lot, and i imported my model from AutoCad… i have the lines that divide the spaces, but if u want those line to be able to be seen in Lumion, i need them to be a solid… theres any plugin, or trick, that i can use to turn a LOT of lines, into a LOT of solids?
Make the parking stripe a component - then use the array function or copy/stamp feature within the Move tool.
You can try this
https://extensions.sketchup.com/extension/60ac8e13-3d3c-4098-bc53-92eab657ba5d/s4u-to-components
Use the function: Lines to components.
I tried but the plugin just makes another line on top of the original
It doesnt change it to a solid that i can see in lumion
I think i need like a super overpowered Follow me, that i can just copy a geometry to a thousand lines
I can do that, but its over 10.000 parking spaces… and not all of them are in line, i think i will be hours doing it that way
You need edit your component.
Or Select 1 face or component before make lines to components.
I was just going to text you this… i was selecting the whole component i wanted to copy, i just needed 1 face in the right direction!, i cant believe it worked! THANKS A LOT! i though i was not going to be able to show those lines haha!
PERFECT! it was just what i needed…
Really cant believe i was able to do the parking lots with 1 click… Thanks a lot! the addon was super helpful!
I will save it for the next one! thanks!
Love it when the community comes through!
