How to get and set texture using C API
Hi gurus.
I have an application (developed using Skechup SDK in C++) that can display SKP file without texture.
But that file has texture, i can get texture detail with these functions
SUMaterialGetTexture(material, &texture);
if (SUIsValid(texture))//if there is texture
	SUStringRef     file_name = SU_INVALID;
	SUStringCreate(&file_name);
	SUTextureGetFileName(texture, &file_name);
but i do not know how to get image data and associate image data with each vertex.
What do you exactly need?
For texture pixels, you should look at:
SUTextureGetDimensions(textureRef, &width, &height, &scaleU, &scaleV);
SUImageRepRef imageRep = SU_INVALID;
SUImageRepCreate(&imageRep);
SUTextureGetImageRep(textureRef, &imageRep);
SUImageRepGetDataSize(imageRep, &pixelSize, &bpp);
SUImageRepGetRowPadding(imageRep, &rowPadding);
SUImageRepGetData(imageRep, pixelSize, (SUByte*)bitmap);
SUImageRepRelease(&imageRep);
For STQ data for vertices:
SUMeshHelperRef polyMesh = SU_INVALID;
SUMeshHelperCreate(&polyMesh, faceRef);
SUMeshHelperGetNumVertices(polyMesh, &numberOfVertices);
std::vector<SUPoint3D> uvs(numberOfVertices);
std::vector<SUPoint3D> backUvs(numberOfVertices);
SUMeshHelperGetFrontSTQCoords(polyMesh, numberOfVertices, &uvs[0], &result);
SUMeshHelperGetBackSTQCoords(polyMesh, numberOfVertices, &backUvs[0], &result);
SUMeshHelperRelease(&polyMesh);
FYI, if the .skp model file comes from someone else, then the path pointed to by the texture filepath may not exist on the computer running your application.
