# How to export multiple 2d views at once
**URL:** <https://forums.sketchup.com/t/how-to-export-multiple-2d-views-at-once/114756>\
**Category:** Developers\
**Created:** [January 29, 2020, 10:01am UTC](https://forums.sketchup.com/t/how-to-export-multiple-2d-views-at-once/114756 "2020-01-29T10:01:14Z")\
**Showing post:** 4
**Post date:** [January 30, 2020, 12:05am UTC](https://forums.sketchup.com/t/how-to-export-multiple-2d-views-at-once/114756/4 "2020-01-30T00:05:27Z")
(_Moving to Ruby API subcategory._)
> [@axelmendes](#):
> I found this code:
Please post using code delimiter **lines** per: [[How to] Post correctly formatted and colorized code on the forum?](https://forums.sketchup.com/t/how-to-colourize-code-on-the-forum-wiki/46189)
**FYI** , There is an error in your code …
```ruby
:filename => "#@path/#{name}.png",
For string interpolation, you need to use `#{ ... }` to delimit the eval expression, so correct is:
```ruby
:filename => "#{@path}/#{name}.png",
It is also a good thing to post a link to where the code came from.
We’ve covered this is other threads. I’ll see if I can search them up …
Here is one example I wrote …
- [[Code] Example: Saving Iso views to PNG image files](https://forums.sketchup.com/t/code-example-saving-iso-views-to-png-image-files/56762)
_[View the full topic](https://forums.sketchup.com/t/how-to-export-multiple-2d-views-at-once/114756)._
