Hi there,
When i choose a image component, then click Edit->image(1 in model)-> export, I can export a image entity as its source file.
First question: Is there any way to do this by ruby? I only find a function View.write_image in API document. But seems like it doesn’t do what I want.
Second question: Is there any way to make this image component encode to BASE64? So that I can post it to a Webdialog as a parameter. Or just, if I can print this image on a Webdialog with some others methods?
Thanks for your help, and sorry for broken English
Weinan
An image entity is a special type of component (that consists of 4 edges and a rectangular textured face). Its material is hidden from the materials list, but it has a material object.
TextureWriter can write textures of faces, but also groups and images. To avoid that perspective transformations are baked into the exported image, most developers apply the material to a temporary empty group. But this should not be necessary here because images in SketchUp have usually no perspective transformation (they are rectangular).
In case you want to access the material object directly: face = image_entity.definition.entities.grep(Sketchup::Face).first material = face.material
SketchUp’s API currently only allows to write image to the file system, not to retrieve (or manipulate) the pixel data in memory. So you would export the image to a temporary folder, and then pass this path to the webdialog.
