How to draw a layer above a construction
Hello there,
For now I did draw everything manually using the line tool.
Very time consuming.
I did add a basic sample skp file, what in this sample my start and goal is. BTW, in several constructions that need a layer they are a mix of groups and components. Also I’am using SU2021.
Any pointers how to do it more easily and faster?
Test_Create a layer above a construction ( asfalt on roof ).skp (109.5 KB)
And of course thank you for any suggestions.
R
With Follow Me tool.
I get the forbidden cursor.
Open the group by right-clicking on it
mvo-04
Thank you for this. Top. I always underestimate the followMe tool.
However I got a mix of groups and components, and can’t select the whole path at once. so I need to do them separately. I guess!
The starting point to get the line to begin with is a problem for me.
In the past I did duplicate the elements/objects to another file; explode everything; select the to follow line; weld it; drag it a little up, and use the Offset tool to create a thickness for the layer. Then did this again for the second layer using the first layer.
I did hope to find a contour tool/plugin that create the outline fo selected objects.
You might get a tip from this video: Skill Builder.
