Here is my code:
edges = entities.add_circle [0,0,0], [1,0,0], 100
face_bottom = entities.add_face edges
face_bottom.pushpull 200
but I don’t know how to get the top face and scale it?
Here is my code:
To find the face try this:
top_face = entities.select { |e| e.is_a?(Sketchup::Face) && e.normal.samedirection(Z_AXIS) }
To scale it around its own center, try this:
transformation = Geom::Transformation.scaling(e.bounds.center, 0.1)
entities.transform_entities(transformation, [top_face])
I haven’t tested the code so there can be spelling errors and such, but hopefully it should get you in the right direction.
it works, thanks for the help!
@xiaowang - please make sure to format code examples in code blocks. That makes it a lot easier to read.
You can use the toolbar in the editor after selecting your code block:
Or you can wrap them up manually by using three backticks: ``` before and after the code.
