excercise no2.skp (91.4 KB)
I’m trying to create a dimension for two parallel edges that are not aligned with any of the inference lines. I can select the two points to measure across but then the dim try’s to align with one of the inferences and gives various incorrect measurements.
File attached. The edges in question bound the orange surface.
You should be able to drag and drop the file, or use the upload icon on the top of the message box.
If the file is larger than around 16mb you would need to upload to dropbox or similar and attach a link to it.
My Ipad is charging.
With Pro it can be easier to add an edge at the point you want and use the dimension tool on that.
You can delete the edge after using it.
I will check on my ipad in a little while and offer better if I can.
It seems to me the best option is as I suggested with Pro, create an edge across the face, then drag the dimension off that, don’t tap the ends or the middle, simply touch and pull the dimension from the edge itself. Then delete the edge.
@Argyletoo, does the IPad version offer an option to change the axes? If so, an other solutions may be to temporarily set an axis along one of both edges. Doing so could also be helpful in other circumstances.
