Error: #<EOFError: end of file reached>
c:/users/patil/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/rs_window/rubywindow_datcol_class.rbe:47:in `readline'
c:/users/patil/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/rs_window/rubywindow_datcol_class.rbe:47:in `block in DC_Read'
c:/users/patil/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/rs_window/rubywindow_datcol_class.rbe:46:in `times'
c:/users/patil/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/rs_window/rubywindow_datcol_class.rbe:46:in `DC_Read'
c:/users/patil/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/rs_window/rubywindow_datcol_class.rbe:20:in `initialize'
c:/users/patil/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/rs_window/rubywindow_load.rbe:57:in `new'
c:/users/patil/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/rs_window/rubywindow_load.rbe:57:in `<module:RubyWindow>'
c:/users/patil/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/rs_window/rubywindow_load.rbe:2:in `<module:RubySoft>'
c:/users/patil/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/rs_window/rubywindow_load.rbe:1:in `<main>'
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `eval'
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `load'
C:/Users/Patil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/RS_Window.rb:22:in `register_extension'
C:/Users/Patil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/RS_Window.rb:22:in `<module:RubySoft>'
C:/Users/Patil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/RS_Window.rb:10:in `<top (required)>'
- How and when do you get these errors? Some more explanation (besides a backtrace) would be nice for people who take the time to reply.
- When you write a post with that contains code, select the code and click the </> button to format code properly so that it becomes easier to read. You can still edit () your post and fix this.
The errors appear to be from RubySoft’s window extension. I’ve never used it and the trace reveals it is encrypted so I can’t inspect the source code. I’d suggest you contact them for help.
