How to bevel sides when a mould is on the ends
Hi
How can I bevel the sides when a mould is on the ends of a piece of wood?
Brace.skp (259.1 KB)
I have attached the moulded brace where the bevels need to run down the sides, I have added a simple version of the brace with the bevels on but no moulds on the ends.
Any help much appreciated
Fredo Scale, Solid Tools or just Intersect Faces
Thanks
I seem to be getting an error saying
No intersections found between selection set
and the rest of the model
Do you have all the geometry in the same context?
Did you use Intersect Faces > With Selection ?
Have you tried Solid Tools? Create both of your objects as solid groups first.
Thanks Solid Tools worked great
Thanks for your help
