I’ve manually set the length of some lines in my model, but every time I now draw a line it snaps to one of these lengths to the extent where it’s almost impossible to draw! How do I clear the cache of defined lengths/disable the snap function?
Under Window>Model Info.Units, untick the box for Enable Length Snapping.
If you want to make that a permanent change going forward, open a new session of SketchUp, make that change and immediately choose File>Save as template. Save the blank file as a template and make sure use as default is checked.
Works a dream - my saviour!
I’m happy it’s an easy fix.
