How do I/ Need Help cut object to follow slope
Hello Im modeling a wall where the wall is sloped. I’m having troubles with making the wood panel object follow the slope of the wall. Need advice, please. The model is attached
Cece Wall Draft.skp (4.6 MB)
If I was doing this I would model a solid “cutter” object to match the slope and use it to trim the panels.
trim
Cece Wall Draft.skp (4.5 MB)
Side note. Take a little time to fix the incorrect tag usage. ALL edges and faces should be untagged.
I tried that but the solid i created is grayed out/ doesnt allow me to select it. Im a novice to sketchup btw
You have to put the cutter solid inside the group containing the panels. You can see that’s the situation in my GIF.
That worked. Thank you for your help
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
