How Do I Join These Two Parts To Have a Clean Corner
Based on what little we have to go on in your screen shot I would say make sure that all the geometry is in the same context, i.e. in the same group or all loose geometry. Then select all of the geometry, right click on it and choose Intersect faces. After that completes, erase the unwated geometry. Make sure you correct the face orientation, too. There should be no exposed blue back faces.
I’m guessing you could have started this differently and use Follow me to create it without requiring the cleanup.
Oh thankyou so much for the quick response. I had a quick look at the ‘Follow Me’ Tool and that actually might work better. Ill try work it out with that. Hopefully goes smoothly. Thankyou
