# How do I change the measurements of a component?◘
**URL:** <https://forums.sketchup.com/t/how-do-i-change-the-measurements-of-a-component/276580>\
**Category:** Dynamic Components\
**Created:** [June 6, 2024, 11:28am UTC](https://forums.sketchup.com/t/how-do-i-change-the-measurements-of-a-component/276580 "2024-06-06T11:28:37Z")\
**Showing post:** 10
**Author:** ![colin](https://sea2.discourse-cdn.com/sketchup/user_avatar/forums.sketchup.com/colin/32/70101_2.png) [@colin](https://forums.sketchup.com/u/colin)\
**Post date:** [June 6, 2024, 5:03pm UTC](https://forums.sketchup.com/t/how-do-i-change-the-measurements-of-a-component/276580/10 "2024-06-06T17:03:13Z")
What I wrote in this message is still the same in 2024:
> [@Components don't appear in "Component Option" Window](https://forums.sketchup.com/t/components-dont-appear-in-component-option-window/4851/20):
> I went back to read the original post, and yes, what you say seems to be the case. Opening Component Options when a component is already select (any kind of component), gives you a working window for the rest of the session. Opening Component Options when no component is selected, gives you a non-working window for the rest of the session. There is one thing you need to do to make sure the problem happens. First open Component Attributes, then open Component Options, and now select a component.…
If you select a component and open the two windows, you won’t see the problem for the rest of that session. If you open both windows before selecting a component, you will see the problem for the rest of that session. When you saw it work in 2023 and not in 2024, you had done different steps.
_[View the full topic](https://forums.sketchup.com/t/how-do-i-change-the-measurements-of-a-component/276580)._
