Most people calculate the opposite thing, but in this case i need to create a rectangle that is exactly 450 sq/ft.
This isn’t the same as calculating square footage, its the opposite. Getting the length and width from the square footage.
I would really appreciate this,
I’m curious about the scenario. Do the dimensions or ratio of the rectangle not matter? If not, then you could make a 10’ x 45’ rectangle, right?
If it’s perfectly square, then would finding out the square root solve the problem? You can Google Square Roots, luckily. The 4 sides of a square 450 sq ft area would each be 21.2132034356, if that is the concern.
Unless you specify either the ratio between the sides (e.g., 1:1 for a square) , or the length of one of them, there is an infinite number of answers for rectangles of a given square footage.
@frogolive, a 1:1 ratio sounds like you just need the square root. You don’t even need a calculator for situations like this, fortunately. I googled “Square root of 450” and it gave me a direct answer. Let us know how that works out for you!
