Hello All.
I want to import and parse the XML file.
I try to search on google, Many methods use a Ruby Gem.
But In Aptana, Ruby Gem is not installed.
can anybody help me with xml parsing?
Are you looking for help with SketchUp or Aptana?
There’s a thread here on installing RubyGems in SketchUp:
An example SketchUp plugin that uses the REXML module is listed below:
[note - the code has been since edited per @DanRathbun’s suggestions]
# (C) 2015 by Aqualung - Permission granted to freely use this code as long
# as this line and the preceding line are included in any derivative work(s)
# jimhami42_osm_importer.rb
# Import OSM-type 2D ways
# version 1.0 (beta) - December 2, 2015 - Initial release of working version
require 'sketchup.rb'
require 'rexml/document'
# include REXML - moved into class module per @DanRathbun's suggestion
module Jimhami42
module OSMPolygonImporter
include REXML
# MAIN BODY -----------------------------------------------------------------------------
class << self
# MAIN PROCEDURE ------------------------------------------------------------------------
def jimhami42_osm_import()
jimhami42_osm_import_init()
@@model.start_operation("Import OSM File",true)
jimhami42_osm_import_get_input()
puts "Start Time: " + @@timestamp.to_s
jimhami42_osm_import_create_polygons()
puts "Created: " + @@poly_count.to_s
@@model.commit_operation
puts "End Time: " + Time.now.to_s
end
# INITIALIZE DATA -----------------------------------------------------------------------
def jimhami42_osm_import_init()
@@model = Sketchup.active_model
@@timestamp = Time.now
@@scale = 1.0
@@poly_count = 0
@@display_bb = "No"
@@name = @@timestamp.strftime("%Y%m%d%H%M%S")
@@bbox = []
@@xnode = Hash.new
@@ynode = Hash.new
end
# GET USER INPUT ------------------------------------------------------------------------
def jimhami42_osm_import_get_input()
base = UI.openpanel("Select OSM File", "~", "OSM Files|*.osm;||")
# base = UI.openpanel("Select OSM File", "%HOMEPATH%", "OSM Files|*.osm;||")
@@basename = File.dirname(base) + '/' + File.basename(base,".*")
puts @@basename
puts "Parsing XML File ..."
jimhami42_osm_import_get_data()
prompts = ["Name: ","Scale: ","Display BB: "]
defaults = [@@name,@@scale,"No"]
list = ["","","No|Yes"]
input = UI.inputbox prompts, defaults, list, "Enter Import Parameters:"
@@name = input[0]
@@scale = input[1].to_f
@@display_bb = input[2]
for i in 0...4
@@bbox[i] *= @@scale
end
end
# CREATE POLYGONS -----------------------------------------------------------------------
def jimhami42_osm_import_create_polygons()
if(@@display_bb == 'Yes')
group = @@model.entities.add_group
group.entities.add_edges(Geom::Point3d.new(0,0,0),Geom::Point3d.new(@@bbox[2] - @@bbox[0],0,0),Geom::Point3d.new(@@bbox[2] - @@bbox[0],@@bbox[3] - @@bbox[1],0),Geom::Point3d.new(0,@@bbox[3] - @@bbox[1],0),Geom::Point3d.new(0,0,0))
end
@@xmldoc.elements.each("osm/way") do |w|
pts = []
w.elements.each("nd") {|n| pts.push(Geom::Point3d.new((@@scale * @@xnode[n.attributes["ref"]]) - @@bbox[0],(@@scale * @@ynode[n.attributes["ref"]]) - @@bbox[1],0))}
group.entities.add_edges(pts)
@@poly_count += 1
if(@@name == "")
group.name = w.attributes["id"]
else
group.name = @@name + '-' + w.attributes["id"]
end
end
end
# GET SHAPEFILE DATA --------------------------------------------------------------------
def jimhami42_osm_import_get_data()
file = @@basename + '.osm'
xmlfile = File.new(file)
@@xmldoc = Document.new(xmlfile)
puts "Version: " + @@xmldoc.elements["osm"].attributes["version"]
@@xmldoc.elements.each("osm/bounds") do |b|
@@bbox[0] = b.attributes["minlon"].to_f
@@bbox[1] = b.attributes["minlat"].to_f
@@bbox[2] = b.attributes["maxlon"].to_f
@@bbox[3] = b.attributes["maxlat"].to_f
end
@@xmldoc.elements.each("osm/node") {|n| @@xnode[n.attributes["id"]] = n.attributes["lon"].to_f; @@ynode[n.attributes["id"]] = n.attributes["lat"].to_f}
end
end
unless file_loaded?("jimhami42_osm_importer.rb")
menu = UI.menu("PlugIns").add_item("Import OSM File") { jimhami42_osm_import() }
file_loaded("jimhami42_osm_importer.rb")
end
end
end
