How can I set the camera location by Latitude and Longitude?
Continuing the discussion from Can I enter coordinates (2d) into SketchUp (Could be UTM or Lat/Long)?:
This plugin could be used to import a CSV file of the desired Camera coordinates.
The result is the imported coordinates are represented by Guide Points in 3D space.
Coords-Tag from Datum v3.4 by TIG — SketchUcation PluginStore
Then use the Position Camera tool to establish the camera location and orientation.
Create a Scene to save the desired view.
I created a plugin that should work in a geolocated model with appropriate location information. You specify the latitude, longitude, height, and direction and it sets the camera appropriately. Seems to work equally well in both perspective and parallel projection modes (the defaults are in Boulder, Colorado).
https://sites.google.com/site/spirixcode/code/jimhami42_set_camera_latlong.rbz
