How can I arrange labels to be in front of object fill?
When I position a label text and leader across an object with fill, it ends up behind the fill. I’ve tried “arranging” the fill to the back and the label to the front. I haven’t found any way to get the labels to appear in front of the fill. The fill I am using is semi-transparent. When I draw curves across the fill area they show up in front of the fill, but when I draw a label leader, it appears behind the semi-transparent fill.
How about putting the labels on a layer higher in the list than the fill or whatever other content you have?
Anyway, you can set your shortcuts to speed up your workflow when the objects (label text, lines, titles…) are on the same layer.
Shift + F to bring to front
Shift + B to send to back
Great! So simple. Thank you for your help.
Good suggestion. Thank you.
