I can not find the function that gets the version of the layout file.
I’m afraid there is none. There isn’t even such function for SKP files.
There is for a model object, but the whole file must be loaded:
The following feature request is still open to read the version from the SKP file header for both the Ruby and C APIs:
Read SketchUp version of external file · Issue #346 · SketchUp/api-issue-tracker · GitHub
The following issues discuss how to do it with the Ruby API:
Reading GUID of external file · Issue #225 · SketchUp/api-issue-tracker · GitHub
Please open a new issue in the tracker for getting version of an external .layout
file.
NOTE: I just opened an issue for reading the version from an internal LO document.
Since .layout
files are zip archives. Your app (or extension) can open the archive then extract the "documentProperties.xml"
file and read the "version"
attribute for the <dp:generator>
element.
Thank you.
verstr = nil
RubyZip::File.open(file) do |zip_file|
zip_file.each do |entry|
zip_file_name = entry.name.force_encoding('utf-8')
next unless zip_file_name == 'documentProperties.xml'
entry.get_input_stream.readlines.each { |line|
verstr = line[/(\d*\.){2}\d*/] if line.strip['<ldp:version']
} if entry.file?
end
end
verstr
