How can change this in layout by ruby code?
It seems to be fixed 2mm.
This setting is not exposed to either the Ruby or C APIs.
Please add a request in the API tracker:
SketchUp API Issue tracker : “is:open” “label:LayOut”
The workaround that I thought (at first) might be possible, also cannot be done because the LayOut API does not yet have a method to change a vertex point of an exsiting Layout::Path object (which can be gotten for a dimension via it’s #entities method.)
