Where can I find the HouseBuilder plugin? My pc crashed, and I lost everything. Maybe someone still has the plugin and can share.
Thank you.
Thank you.
You should be able to find that ancient extension at Sketchucation.
Hi Dave,
Thanks for getting back! I been looking in there; I cannot find it anywhere. I will continue searching, and I been at it for the last hour.
Have a good day!
Sketchucation was the source for it for a long time. It might be permanently gone now. It was seriously outdated and there are better extensions available.
I found this. Use it at your own risk, though.
Thanks! Yes it looks like its gone and thanks for that website, it looks like download still available but my Chrome browser not letting me to access download for security reasons. I disabled security but still not letting me to access download. I will have to play around and see what preventing me to get that download if not so be it I guess unless someone has that plugin and will upload it to one of the file sharing sites. Will see.
Thanks for all your help I really appreciate that.
i installed 2027 and the first thing it reported as not valid - housebuilder (followed by profile builder 3, su podium, and a couple of other paid plugins) oddly enough many free plugins with (imho) less than stellar programming as ok though. i’ll have to see what’s causing the house builder to fail “validation” as i do use it to quick sketch a framing idea before pulling in my dynamic components or Medeek Wall.
I wouldn’t hold my breath on the ancient Housebuilder extension getting any updates. The last update was probably a decade ago. Maybe longer.
I have an older version of SketchUp just for that plugin, the 2013 version. If you still have it I would appreciate if you can share it with me.
Thanks!
Update! Thank you for all your help! Thank God to AI, I found the download; I just tried it in SU 2026 it works fine.
If anyone is looking for it here is the link
I’ve also just posted RBZs for the '/" and metric versions on the SketchUcation forum, but it will raise errors in newer SketchUp versions and also needs manually installing…
There are much newer, free extensions available…
You can try checking the official plugin website or community forums to see if anyone still has the HouseBuilder plugin available. Hopefully, someone can help you find a working copy or an alternative. Good luck!
