I have noticed that the horizon, which is the change of colour from a blue to a brownish in the background to views/elevations can change position. For example looking at a elevation and then shutting the file down and opening it directly after the horizon seems to have moved and is not in the desired location of being at the bottom or ground level of our models.
My question is what controls that horizon position?
I have looked into styles which does help with colour changes but cannot find anything that helps with the horizons position.
The screengrab with a simple rectangle is a front elevation view from our template.
The screengrab with a detailed model is a front elevation view from the template file which you may note the horizon is in a different location. No axis change was changed. It appears the axis has lowered as we modeled but cannot pin point why and how.
Thank you for the screenshots, but without the model it is still hard to determin why it changed.
I have tried to reproduce something simular, but the horizon did not change (yet).
Hmm, so unfortunately don’t have a sollution (yet)
