Hi Guys,
Am I going mad here? I created a component and hid all the lines before saving. When I open this file, the lines are hidden. When I then bring it into a model via collections, the lines are displayed. Is this the normal behaviour?
If you model has a Style set up not to show any lines, then it doesn’t show them. But if you save a component out and import it into another model, AND that model has a Style set to show lines, then lines will show up. All is not lost. Edit the component-instance and Select > All, right-click > context-menu > Select… submenu lets you deselect faces, now only edges should be selected. In Entity Info choose the icon the Hide the selected edges. The edges should now disappear. To see them temporarily toggle the View > Hidden Geometry on/off and they’ll appear dotted. If you now export out that component whenever it is imported into another model the edges will not show - unless that model’s scene has View > Hidden Geometry ‘on’ in which case they’ll appear dotted. You can’t hide edges permanently as there’s always going to be a way to see them, they are needed to support their associated faces, so deleting them is out of the question, and using tags is ill-advised because faces and edges should be untagged and their ‘container’s’ tag used for visibility - having different tags for faces and their edges quickly leads to madness when editing one affects [e.g. moves or deletes] the other perhaps unseen entity !!
