Using hideall.rb extension in Sketchup Make 2017. I’m finding that in larger models, using the hide-all-unselected add-on causes a major slowdown for a good 30-60 seconds, after which it picks up again and editing can continue as expected. But for that time it’s unusable. Anybody else getting this?
The script goes through all the entities (including all individual edges, faces, components groups…) one by one - in the current context - and checking them if they are selected, then hides them if not.
So if there are a lots of entities, it will takes time. During that time SketchUp is busy with this operation and can not respond other command. I say it is an expected behavior.
That makes sense but the slowdown occurs AFTER the operation… like this:
select object(s) to isolate
press [h] to isolate selection ([h] is my shortcut key for hideall)
unselected objects are hidden immediately
major slowdown for 30 secs
slowdown ends suddenly and editing of isolated object can continue
press [u] to unhide all, no problems
The model is also well layered, and any unnecessary layers are hidden at the time.
Would you still say that this is expected? Do recent versions of Sketchup have this as a native feature? I find hide rest of model in component edit to be a bit awkward if I want to snap to other objects.
__
As I tested quickly with the unhide.rb and with native tools method the same slowdown will happen in both cases.
But check what will (not) happen if you close the Outliner…
