Hidden Lines showing up as Solid on Layout
Hi,
Since the new version all the hidden lines in the model appears as solid lines in LayOut. How can I make this disappear again in LayOut as in the SU model intended.
Thanks for hints.
Have got draft mode enabled?
Post your file so we can see how you have it setup.
I found the solution. It’s pretty simple and maybe has to do it with my developable LayOut skills. It’s important to switch of the unvisible lines by hidding them in the model. As soon as hidden lines are shown in SU with dotted lines (the object property is hidden) they will appear as solid lines in LayOut.
Many thanks so far for the support.
